Old Allen - Bradley 6200 software for the PLC2 series. Floppies are self extracting.
[dead] :/428388166/PLC26200.rar
Rar password is: plc26200
[LINK]: AB 6200 PLC2 Software
diegozuluaga81
Re: [LINK]: AB 6200 PLC2 Software
Hello Neuhauser
I´m trying to study an ladder program under PLC2-6200 software but I don´t have this software. Your link is broken. Could you give me that software, please? I have the AI2 software but the syntaxis is different.
Thank you very much for your help!
Diego
Diego
diegozuluaga81
neuhauser wrote:Old Allen - Bradley 6200 software for the PLC2 series. Floppies are self extracting.
Hello Neuhauser
Diego
Daniel_Brasil
Hello to all,
Here are the two downloadable software:
http://neo-share.com/files/N6N9F9AI/PLC2.zip
Password: plcforum
best regards
Password: plcforum
best regards
Hello! I need AB 6200 Software for an old PLC5. I have the program software but I can't open it with RS Logix %, it requires AB 6002. All the AB 6002 link here are out of date, can anyone help me? THANKS!!!!
You don't need it, you can use RSLogix 5 to import the 6200 routines:
.RSP Project file created using RSLogix 5. It contains the ladder program files, all accompanying database documentation, and the custom data monitor and multipoint monitor address lists if any exist.
.X5 Project file created using the WINtelligent Logic, PLC-5 AI Series, or 6200 PLC-5 programming software. X5 files created using WINtelligent Logic and PLC-5 AI Series software contain the ladder program files and accompanying database documentation. X5 files created using 6200 PLC-5 programming software will not automatically import any accompanying documentation. Perform a native import of the AB 6200 database after opening the X5 file to attach the documentation. (Step-by-step instructions for importing the documentation are included in Opening a project.)
.RP1 Compressed-format backup file. This is an .RSP file that was saved for archiving using a built-in compression utility. Opening it gives you complete access to the .RSP file as described above.
.IB1 Compressed-format backup file. This is an .X5 file that was saved for archiving using a built-in compression utility. Opening it gives you complete access to the .X5 file as described above.
.PC5 Import/Export files. These processor memory files in the form of ASCII files contain the ladder logic, SFC files, structured text, data table files, and force tables for your programs.
.AF5 Processor memory file created with version 4.1 or later of the 6200 PLC-5 programming software.
.CAR A subroutine custom designed for a specific type of application. It is invoked by a custom I/O routine instruction (CIR or COR) in the ladder logic program.
Anyone with a working link for 6200?
