[LINK]: ABB relays PCM600 Engineer Pro with IEC61850
другие контроллеры
rose2cactus
Post by rose2cactus »
hello to all
has anybody had software PCM600 Engineer Pro with IEC61850 ?
Could you upload it?
also software tool for ABB CAP505??
i need it :lol:
mytom123
Re: Request: abb relays PCM600 Engineer Pro with IEC61850
Post by mytom123 »
Here you can download CAP 505 V2.3
http://www.mediafire.com/?936622boparrnbl
and upgrade to V2.4
http://www.abb.com/product/db0003db0042 ... country=VN
I need PCM600 pro too. Anyone has it? Could you upload it?
Rdgs.
rose2cactus
thnx buddy...i still cant find pcm600 ...but i'll tell u when i have it..!!!
leofarhan
Post by leofarhan »
Download the PCM600 from [dead] :/432287980/PCM600.iso
I need ABB Testing Software for IEC61850. There are two software.
ITT600 SA (Commercial)
ITT SA Synchronizer (For ABB Internal Use)
Kindly upload, if you have.
Regards
Leo-Ali
rose2cactus
i am not able to download it from this link...please post another link asap
thanx in advance
Link
Forum Community
Forum Community
Post by Link »
Hello
I have a PCM 600 software v2.3 CD - possible latest version at the present day.
I never use it and never install. So if you got errors during install or usage I can't help you. If interesting - linkz be low:
PCM600-23_ver_2.3.part1.rar http://depositfiles.com/files/ab7wb87l1 Size: 200Mb
PCM600-23_ver_2.3.part2.rar http://depositfiles.com/files/s3b8j35lq Size: 200Mb
PCM600-23_ver_2.3.part3.rar http://depositfiles.com/files/7vs8eb8b1 Size: 155Mb
Before install check in the PCM600 installation guide: maybe some setup prerequisites required.. :?:
Regards
mytom123
Re: [LINK]: ABB relays PCM600 Engineer Pro with IEC61850
Post by mytom123 »
Hi
Has anybody had "RE_ 670_IEC Connectivity Package" for PCM600 2.3 and "Communication Configuration Tool (CCT)' ?
Could you upload its?
Rdgs.
Link
Forum Community
Forum Community
Post by Link »
mytom123 wrote:Hi
Has anybody had "RE_ 670_IEC Connectivity Package" for PCM600 2.3 and "Communication Configuration Tool (CCT)' ??
CCT v4.1.3 you can get here: http://depositfiles.com/files/9723ouigp
I have a Relion 670 Series IED Connectivity Package, not an IEC. Are you sure you looking exactly for RE 670 IEC Connectivity Package?
mytom123
Post by mytom123 »
Hi
I have seen before with PCM 600 1.5 they have package software call "RE_670 IEC Connectivity package" and "RE_670 ANSI Connectivity package " included "RE_ 670 Connectivity Package Base v.1.5r07" and Transmission IED modules ( RED670, RET670,...) . I do not know that it is same or different with "Relion 670 series IED Connectivity package".
Brgs.
Linkinx64
Post by Linkinx64 »
I have this software:
If this is what u looking for I can upload and drop the link (Unpacked size - approx. 900 MB).
mytom123
Post by mytom123 »
Plz upload it
Thanks.
Link
Forum Community
Forum Community
Relion 670 Series Connectivity Package v2.1.3
Post by Link »
Here we go
Relion-670-ConPkg_v.2.1.3.part1.rar http://depositfiles.com/files/se4caied2 Size: 220Mb
Relion-670-ConPkg_v.2.1.3.part2.rar http://depositfiles.com/files/qkoxngifv Size: 220Mb
Relion-670-ConPkg_v.2.1.3.part3.rar http://depositfiles.com/files/fhperv3nl Size: 220Mb
Relion-670-ConPkg_v.2.1.3.part4.rar http://depositfiles.com/files/kcedxigix Size: 204Mb
segamega
Post by segamega »
freeeek
Post by freeeek »
...I have a PCM 600 software v2.3 CD - possible latest version at the present day.
I never use it and never install. So if you got errors during install or usage I can't help you. If interesting - linkz be low...
Someone can tell me about version of this product
PCM600 or
PCM600 Engineer?
I need graphical application configuration but I didn't find this.
spak
Post by spak »
Hello evrybody,
I'm looking for some ABB manuals.
Does anybody has Technical Descriptions of Functions (CD-ROM) 1MRS750889-MCD and would like to share it?
homeniuk
Post by homeniuk »
Does anybody have PCM600 Engineer or Pro?
I need graphical application configuration but I didn't find it.
Also I can not find CAP 531.
Is this the same thing?
greenman
Post by greenman »
leofarhan wrote:Hello,
Regards
Leo-Ali
I have got both ITT600 SA Explorer and ITT SA Synthesizer, but they don't work without licenses.
From user manuals:
ITT600 SA Explorer provides only one way for licensing:
- License bound to a PC (Hard disk ID)
License bound to a PC means you will receive one license per
installation on a PC. To run the ITT600 SA Explorer on another
PC, users will need a new license for that PC (this is also called
node-locked).
ITT SA Synthesizer Licenses are file based and node locked
licenses.
NOTICE:
Licenses are not transferable between PCs! Every installation
needs its own license.
leofarhan
Post by leofarhan »
Hello Greenman,
Can we run them for demo period, if so can you upload.
Thanks & Best Regards
Leo-Ali
ostogradski
Post by ostogradski »
The link of PCM600 [dead] :/432287980/PCM600.iso is no more valid.
Also, I need the ITT600 SA Explorer. Please HELP.
(sos) .
Linkinx64
Post by Linkinx64 »
greenman wrote:have got both ITT600 SA Explorer and ITT SA Synthesizer, but they don't work without licenses.
Any updates? Pls. share these 2 tools with me too.
Thanks in advance!
mytom123
Post by mytom123 »
Anybody has this software?
Plz upload it.
Brgds.
kankanaka
Post by kankanaka »
I downloaded CCT 4.1.3, patched it. It is working but, when I try to import ICD file, appearing "key not found " message.
Is there another version or another patch.
Best Regards
Rudi
Post by Rudi »
Hi guys
I had to work with ABB stuff several times. PCM600 latest version is 2.4. Even the basic version should be registered via ABB Server. You must create a special key, send it to ABB and they return you a valid license. There is no way to bypass the registration process unless someone is able to crack it.
Worst of all is IET Tool 5.1 and ITT600. Those software comes from ABB Switzerland and is much more protected than PCM600. The software doesn't run on a virtual machine neither via terminal server. Without crack there's no chance. Sorry to say that. Even inside ABB you have to buy a license wich is fixed to a special notebook or PC. If someone has got any news, please post it here. :mrgreen:
Rudi
Linkinx64
Post by Linkinx64 »
kankanaka wrote:I downloaded CCT 4.1.3, patched it. It is working but, when I try to import ICD file, appearing "key not found " message.
I had imported a couple ICD files for test: no any "key not found" message or other warnings I got.
Could you upload your ICD to let me try?
Rudi wrote:Worst of all is IET Tool 5.1 and ITT600. Those software comes from ABB Switzerland and is much more protected than PCM600.
I have seen cracked internal versions of ITT600 SA Explorer and ITT 600 SA Synthesizer on forum.
hina
Post by hina »
Dear All,
Could you Please Re upload CCT 4.1.3 because the link already dead
Best Regards
Linkinx64
Post by Linkinx64 »
hina wrote:Could you Please Re upload CCT 4.1.3 because the link already dead
Link is alive. Another link is: http://www.4shared.com/zip/kTMdpPxd/CCT ... _Conf.html
mytom123
Post by mytom123 »
Hi
Has anybody had PCM600 2.4 Engineering ? Could you upload it?
The PCM600 2.4 basic version only support parameter setting, not support application configuration.
Brgds.
softwareguy10
Post by softwareguy10 »
Hi
PCM600 2.4 SP1 doesn't require a license anymore! Basic functionality and Graphical Application Configuration (Engineering) is now free. You don't need any license keys at installation. You only need license for the IET600 Tool (license must be ordered separately). You can download PCM600 here: https://www143.abb.com/SoftwareLibrary You only need to register once to get an account to be able to download.
Use the Update Manager that comes with PCM600 to download Connectivity Packages for relays.
mytom123
Post by mytom123 »
Hi
Thanks a lot for your support
Brgds.
hina
Post by hina »
Dear All,
Can you please upload CCT600 4.1.3 patch...?
Best Regards
Java_user
Post by Java_user »
I would need ITT 600 SA Explorer. How can I get it? Only for testing the software.
Thanks in advance.
gulyabani7
Post by gulyabani7 »
Hi Linkinx64
I have smilar problem when i want to upload ICD file. "key not found" mesage appear on the screen.
Could you help. (sos)
https://hizliresim.com/6yNgy9
Best Regards.
