I need to program the models of panels (TP177micro and OP73micro) which are compatible with Siemens 200 PLCs.
From Siemens website I argued that I need WinCC Flexible Micro.
It seems that there's no useful link in this forum for that software (only the complete WinCC Flexible 2008).
Is there any possibility to install only WinCC Flexible Micro from the installation files of WinCC Flexible 2008 (that seems to be a quite heavy and big software)?
Thank you all in advance.
[?]: WinCC Flexible Micro
Re: [?]: WinCC Flexible Micro
WinCC Flexible Micro = DVD WinCC Flexible without USB stick(no license key) + CAL paper
=105€
WinCC Flexible Compact, Standart, Advanced = DVD WinCC Flexible with ilicense key on USB stick + CAL paper =212€/1049€/1855€
viewtopic.php?f=36&t=8650
verticale128
Thank you very much. So I guess I just have to get a WinCC Flexible 2008 and use it without any license key...
is not licensed! do not use in your factory only for home use
for your factory you need it:
CoMod wrote:WinCC Flexible Micro = DVD WinCC Flexible without USB stick(no license key) + CAL paper=105€
