Hi all
please can any one show me pin out for cable to conncet the pc to CQM1H-cpu51???
Best regards
Maher
[?]: Going online CQM1H-CPU51
maher
maher
Hi all
it is the first time for me to use PLC OMRON type ( CQM1H-CPU51):
I am working by CX programmer 8.1 , and the cable which assigned in this site ,
but i remarked that when i am trying to online the program doesn't show this PLC type and the connection would be failed ,
After that i make updating for the program to CX-programmer v8.33 ,:
and trying again to go online but the following window are appeared _
i am trying to establish the connection between the pc and the plc by the PRPHL. port ( by using the previous assigned cable )
auto online searching :
plc: CS , CJ , CP series , CV series
communication : com3, 115200,none,8,1
protocol: toolbus
is this program not supported ( CQM1H-CPU51 ) type ?
why tell me why?
so please tell me how can i go online for this plc ?, and uploading the software from the plc.
Best regards
Maher
protocol: toolbus
why tell me why?
Best regards
Maher
maher
Re: [?]: Going online CQM1H-CPU51
Please no time
I wait the reply urgently
Best regards
Maher
Best regards
Maher
maher
Hi
Please i want to know if the previous connection is suitable for this type of cpu51 or , it will need adapter ?????
please i am in bad need of the reply urgently
Best regards
Maher
Best regards
Maher
intruder001
Homeroid_BL
With cables shown, you can use ONLY RS232 port on CQM1H.
