Dear all,
You can't imagine how happy I am that the forum is back.
Anyway, I just finished a project using Step7 & WinCC Flexible for a plant, the project is going to be run on PC station.
I'm going to install only WinCC Flexible Runtime on the machine, and deploy the .fwx and .pwl files.
Since the plant owner will probably try to copy the project to other identical plants.
What I'm looking for is a way to protect the project from being copied.
Since MAC address is supposed to be not changable, I was thinking maybe to check & compare the MAC address of the PC, and to terminate the Runtime if there is no match, hence guarantee that it is run on this specific computer. Is it possible to write a script for such a thing ?
Your help is VERY MUCH appreciated,
Thank you
[?]: WinCC Flexible Project Protection
Re: WinCC Flexible Project Protection
with download uncheck "enable upload" & into your computer download only runtime file
over people can not change any settings (connecnion to plc,screens,etc...)
Q-rius
Thank you Sania for your quick response,
unfortunately this will NOT solve my problem.
In this case, it IS true that he will not be able to edit anything, but he will still be able to copy it and run it on a different computer which is what I'm trying to avoid.
Any other ideas ?
Any other ideas ?
you can copy & run in over pc,but connection to plc can not change
Q-rius
Re: [?]: WinCC Flexible Project Protection
Thank you Sania for your patience,
I get that, but what I'm worried about is:
if he duplicates the PLC, when the WinCC Flex is copied, it IS going to work with the same connection.
here's what I wrote so far, but I wish I knew any better ideas:
Please comment
Dim shell
StartProgram "CMD", "/T:70", hmiShowMinimized, hmiNo
shell.SendKeys("@setlocal enableextensions" + "{ENTER}" + "@echo off" + "{ENTER}")
shell.SendKeys("For /f {""}tokens=3 delims=,{""} {%}a In {(}'{""}getmac /v /fo csv /nh | findstr Local{""}'{)} do set b={%}a" + "{ENTER}")
shell.SendKeys("CLS" + "{ENTER}")
shell.SendKeys("If {%}b{%}=={""}00-1C-00-00-00-1C{""} {(}@echo OFF{)} Else {(}taskkill /F /IM HmiRTm.exe /T{)}" + "{ENTER}")
shell.SendKeys("If {%}b{%}=={""}00-1C-00-00-00-1C{""} {(}@echo OFF{)} Else {(}taskkill /F /IM HmiSmartStart.exe /T{)}" + "{ENTER}")
shell.SendKeys("If {%}b{%}=={""}00-1C-00-00-00-1C{""} {(}@echo OFF{)} Else {(}taskkill /F /IM HmiLoad.exe /T{)}" + "{ENTER}")
shell.SendKeys("Exit"+ "{ENTER}")
Set shell = Nothing-
Scarch
No way... either you give the file or tell the customer that do not want to do it... if they request you the file, they will be annoying you in case is not working...I mean, better speak clear and say NO
