hello
I have old s5 plc 6es5-103-8ma02 and step 5 but a don't know how to upload the plc program to my ste7 can anymore help me or give me the procedure
[?]: upload program s5
isteak007
Re: upload program s5
Open Step 5 then go to file Select Blocks
Transfer------Then write as for all blocks
then transfer
then transfer
Schtiel
If you need to convert your S5 application to S7, just follow this manual:antihard wrote:hello
http://support.automation.siemens.com/U ... en/1118413
Trafo
Re: [?]: upload program s5
First, you need setup physical layer. You need RS232/20mA converter. There are serveral converters on market.antihard wrote:hello
For CPU103 you will need active converter.
Step5 you already have.
With that two things you can make upload.
But your uploded code wil be poor. No labels, no comments.
After that you can make conversion S5 files in step7.
