[?]: emulator for Spac Automazione 2010
Duca99x
Hi! someone have this emulated key for Spac Automazione 2010 ?
thanks
thanks
Mesner74
Re: [?]: emulator for Spac Automazione 2010
please maverik create dump file for spac2010
Please guy426 create emulator for spac2010
Thank you
Thank you
guy426
xblu
Thank you Guy, you are very good
xblu
Guy426,
Please help me! the installation goes well, but when i run the program, appear a window that say " protection key absent"
How can i do? thank thank you
xblu
Hello Djto, do you have solved the problem?
guy426
xblu
Hello Guy426,the program run very well, thank you for your job, you are great!
fortee
guy426 hello, I'll offer my congratulations, great job you're great.
sakan
the emulator ask me 12 digit....
but i have 18 digit with 2 space.
what can i doooooooooooo?
miacrer
Hello guy426.
Congratulations for your work.
I want to know if there is the possibility to run the emulator under windows 7 64bit ... I read in web that is possible with the use of the file DevCtrl.exe instead of wdreg.exe...you have any idea about it?
Thanks in advance.
xblu
hello guy426
can you create the emulator of SPAC AUTOMAZIONE 2011 for Windows 7 64 bit?
thank you
thank you
xblu
Hello Dito, why don't you install 2011 version? you can download it at www.sdproget.it
this one run perfectly
Hi and hi to guy426
Hi and hi to guy426
djcatalyst
MareBlu
[url]h++p://w+w.sdproget.it/Download/IsoImage_Download.asp?productID=SPAC%20Automazione%202011[/url]
virbru
Hello
I need the module cables (modulo cavi) Spac2011Automazione
Thank you.
Thank you.
xblu
Djto Hello, I tried to install it on 64bit windows7 and did not work, I think that the emulator only works with XP
Mesner74
Y have a problem.
the driver "eutron" in the windows 7 x64 don't no install
set the "wdreg" with the administrator, y don't no install
i have a lpt1 installed y working.
please help
please help
maverik53
@ Mesner74
Select Wdreg.exe (C:\Windows\system32\drivers)
With the mouse right button go to Property
Go to TAB Comptibility e select run in Windows Xp SP3 mode.
Install the program.
I have tested on Win 7 32 Bit
Mesner74
in the windows 7 64 bit not work
mpautomations
I have the same problem, on windows 7 64bit and on windows xp.
p.s. the fisically lpt port is missing.
Please somebody help me!!!!
Paolone
Hello to All
I'd install Spac 2011 and copy *.aut in the key folder, but when I run spac2011 still the message Key Absent
If I check the Key with the Hardware key program Tell me that the key is good
What's wrong?
Thank all
What's wrong?
Thank all
alex_the_bes
Please Can You Put the links?
The oldest no more working
Thank You
Thank You
alex_the_bes
Can You re-post on another file sharing this Crack and Keygen Please?
I'll appreciate that.
Thank You in advance.
sharp73PC
guy426 wrote:
Crack + keygen for Spac Automazione 2011
Enjoy!
http://www.megaupload.com/?d=0W1LUKV0
hi guy426, the you posted is not running.
can you please tell us where we could find it, posting an update link?
thank you very much.
I have another question: i tried to install spac automazione 2010 in several pc, beu the installation wizard program tells me, at the first step, that ther is an error of the Date of my pc. and the installation aborts. I tried to change the Date of the system , but nothing changes. can You help me?
the OP i tried with are:
W7 ultimate 64 bit
W7 home edition 64 bit
XP SP3 32 bit
Enjoy!
W7 ultimate 64 bit
XP SP3 32 bit
Dendoh
Does anybody have a working cracked spac? 2010 or newer
GAVAMAR
Hello All,
I need the same think for install Spac Automazione 2010 or 2011.
If somebody have this Crack + keygen I will be very happy.
Thanks in advance.
Thanks in advance.
