Hi Friends
I have an OP17 (6AV3 617-1JC20-0AX1) that I have no pass level 9 for it.
Is there any possibility to remove or showing this paas?
The configuration back-up is no available. so I cannot reset the configuration.
Can u suggest me a way that I could upload the configuration in PG and see it via
Protool without need to know the password?
Sincerely
Mazdak
[?]: OP 17 Password
ppp
Re: OP 17 Password
1. Power OP17 off
2. Press "Esc"+"Up" and power OP17 on.
OP17 in mode "Transfer"
3. Use program Prosave make Backup OP17.
4. Password detect use viewtopic.php?f=4&t=8598
mazdak
Re: [?]: OP 17 Password
Dear PPP
I followed your Instructions to put the OP17 in transfer mode and get the back-up file ".psr"
Then I used the Prosave Decoder to generate "result.txt" and it shows the pass as :00000100 (I guess it should be default pass)
Now, I have 2 questions:
1- Which pass level is this? (I've seen in Op17 manual that some actions need Pass level 9 and some the lower levels)
2- How can I get the source configuration of OP17 that could be seen or modified via protool ?
Sincerely
Mazdak
Sincerely
Mazdak
ppp
Possible is and other passwords for other levels.
See file decoded.txt in WinHex.
mazdak
Dear PPP
I open the "decoded.txt" with WinHex. But I didnot see pass levels
and what about the first questin. How can I get the source config of OP 17 that can edit it via protool?
Mazdak
Mazdak
mazdak
all friens
can any one help?
How can I Upload the configuration from OP17?
tha Back-UP file ".psr" that is uploaded by Prosave, is not usefull for me.
I need to change the configuration and download it to OP again!
Is there any solution?
Sincerely
Mazdak
can any one help?
Sincerely
Mazdak
Scarch
No way, you need the original file, the psr is used as a backup only. The decoder is useful to know the tags, in case you want to use another operator panel. Password 100 is the original one.
