Hello! I work with CQM1H CPU51& HAKKO V706.
After using few times simulator in V-SFT5 for HAKKO cannot connect with CQM1H CPU51 (shown Communication error).
I check comm parameters, cables etc...
Any help? Thanks!!
[?]: CQM1H & HAKKO V706
cvlsam
Re: [?]: CQM1H & HAKKO V706
Your wiring diagram is whether correct?
The communication actuates whether to have chosen Sysmac C?
Wiring Diagram:
Regards
Wiring Diagram:
Regards
dikobraz
Yes, my cable is correct. I check cable, comm parameters but stil have problem. Any more sugestions?? Thanks!!
Homeroid_BL
Checked serial mode (232, NT, 1:N NT...)?
dikobraz
Yes I cheked that, and thats OK. This problem hapened after I use simulator in V-SFT 5 several times... I chek everything but I stil have problem... Any other sugestions?? Thanks!!!!!!!!!!!!!!
cvlsam
If your cable is no problem with the settings, uncheck USE Simulator download option.dikobraz wrote:Yes I cheked that, and thats OK. This problem hapened after I use simulator in V-SFT 5 several times... I chek everything but I stil have problem... Any other sugestions?? Thanks!!!!!!!!!!!!!!
If you still can not solve your problem, then the first test about your hardware is working.
Regards
dikobraz
Thanks but I stil have problem.....
