Hi guys!
I need know, which HMI i can use wich PLC Mitsubishi series A ??
factorylink ?? intouch ?? indusoft ?? CitectScada ?? Elipse ??
Tanks !
						Which HMI use with PLC Mitsubishi series A ?
				tiagocoelhom
				Linkinx64
Re: Which HMI use with PLC Mitsubishi series A ?
Use the HMI which meets most of your needs or which you get used to. If PLC connected to the HMI via OPC any of those can be used. Even WinCC or 800xA. I never worked with the MMC A-Series but experienced connection different other controllers to different scadas. OPC philosophy makes such connection platform and PLC independent.
				Oldman
InTouch or Citect
				tiagocoelhom
tanks!
i have an factorylink's key.. i wanted to usage this key.
how i communicate the PLC with HMI?
With seria cable, usage protocol RS422.. to communicate with computer?
The comm's cable can usage to communicate in SCADA system? ex: PLC -- comm's cable (SC09) -- computer
|____||_________________| |_______|
How is a PLC Series A, you must use a communication card?
tanks.. people!
tanks.. people!
				af.naderi
hi,
you can use Wonderware InTouch as HMI.
It connect to Mitsubishi A Series PLC by MTEthernet DAServer very easy.
				tiagocoelhom
af.naderi wrote:hi,
tanks!
but,
you can help me, becouse, i have a key for factorylink, do you know communicate the plc A with factorylink ? What i need?
