Hi every body,
I have a IFix Project and want to use graphic pages in Wonderware InTouch.
Is it possible?
[?]: IFix to InTouch
Umencho
Re: [?]: IFix to InTouch
Direct conversion is not possible. You could export The Fix database to .csv, then you can get it into the WW tagname.x file. The database conversion utility (such as gdb2csv) will be of most help with converting database elements where no logic (other than simple alarming) is performed. Scripting is different, as are the graphics, and trending... Basically you could only try to add Ifix' tags to intouch and to build by yourself all the other things.
BR,
Umencho
BR,
Umencho
af.naderi
Thanks Umencho for your help.
But i want use (export, transform, ...) IFix graphic Pages in InTouch.
Is it possible?
Is it possible?
