dear,
I have a problem to export my project to PDF.
I dont find to export to pdf only (jpg, bmp, tif,etc...)
Do have someone a printscreen ore something do how i do?
Normaly u choose your project( page navigator) then go to Page--> export->pdf but i dont have or do i something wrong?
[?]: export eplan project to PDF
Schtiel
Re: eplan project to PDF
You can use any PDF printer and print to PDF instead of paper. For example, this one
yigit111
OW thx i download it now. DO u have also a project (sample) for SIEMENS S7-315-2dp?Schtiel wrote:You can use any PDF printer and print to PDF instead of paper. For example, this one
grtz
yigit111
But i dont have a printer?yigit111 wrote:OW thx i download it now. DO u have also a project (sample) for SIEMENS S7-315-2dp?Schtiel wrote:You can use any PDF printer and print to PDF instead of paper. For example, this one
grtz
And how it works? dont have something else?
Umencho
You don't need a printer. Just install this program and give command print. There select this PDFCreator and you'll receive message after pushed OK where to save this file...
yigit111
Really sorry but i can not do anuthing..
I open the PDF CREATOR--->then i have a empty excel sheet like that.... I can not choose my .zw1(eplan project)?
I want to safe my project in a PDF format.
Umencho
Re: [?]: export eplan project to PDF
You should install this program. Then just open your project in Eplan and give from File-> Print. The next step is to select which printer will use. And exactly here in all available printers which are connected to your PC you will have also PDFCreator Printer or similar name. Select this printer and that's it. This virtual printer will not physically printing your project only will convert to pdf file and save in place which you will assign.
yigit111
Uffcourseeeeee:) its a virtual pdf printer:) thx so much.
do u have also a simple PLC siemens cpu315/dp project?
grtz
grtz
Umencho
Sample project contents CPU 315-2DP regards what?
yigit111
Yes if u want sir.
Umencho
jian68000
Maybe you have not choose mode "professional" when open eplan,choose it then the export menu will appear,if the choose screen does not pop , settings-user-display-user interface select"active hidden msg".(My eplan is Chinese version,maybe not match)
My English is not good,hope can help you~
