Request: uniop designer v.5.03
Does anyone have the program designer Uniop rel. 5.03 or rel. 5.0x?
gurumisiek
Re: Request: uniop designer v.5.03
I'am looking too.
Have anyone UniOP Designer 5?
I am looking too. Does any one have a link to version 5.03 or similar. V6.10 is too new.
Link: https://easyupload.io/m/g430jq
Content:
- Designer 5.07 Setup: Designer 5.07.rar
- Designer 5.08 Update: Designer 5.08.rar
- Designer 5.08 Service Pack 8 Update: Designer 5.08sp8.rar
- Designer 5.08 Service Pack 10 Update: Designer 5.08sp10-50810.rar
- tn154-6 (NewFeaturesInDesigner5.08_UniOP4.40)
- tn179-03 (Designer Users manual)
Content:
RHerrera15
Hi ! Could you please update the link because is down :c I really need this program, I need to upload a program from UNIOP MODEL EK-11.
Here you go: https://easyupload.io/qa10ef - UniOP Designer 5.08sp10 Setup.rar
Please can update the links ?
Thanks a lot !
Thanks a lot !
UniOP Designer 5.08: https://ufile.io/jhv18quoRe: Request: uniop designer v.5.03
I Would appreciate it,
I need Designer 5,to upload the program from etop05.
Gergis
Gergis
Oldie, but goldie: https://ufile.io/ugwwh2ea
Can you update download link?
Mshafik0227
Could you please send available link to download a software ??
Can you send a working link for uniop designer v5.3 ?
does anyone have designer v 5.3 or something older?
I have uniop model ES-16N, I tried designer 6.x, 5.7, 5.8 but none of the versions recognize the panel.
It has the old firmware V4.20 which is shown on the screen and on the back panel is this mark:
Model ES-16N
6ZA991-7
Date 03/2000
H/W V. 33A
S/W V. W33 4.24
Model ES-16N
6ZA991-7
Date 03/2000
H/W V. 33A
S/W V. W33 4.24
I searched my list of UniOp devices on the computer, but I can't find model ES-16N. Contact local support (https://www.exorint.com/en/support) to obtain the firmware files. Shouldn't have any problems with licences, since it's an old, fased out product.
Basically you need to obtain the "ES-16N.dat" description file and it's associated image "ES-16N.bmp". Copy the retrieved files to the designer "/Panels" folder and the ES-16N device will appear in the panel model list the next time you launch Designer software. I recommend using Designer 6.
Example of ECT-VGA.DAT content (device description):
; File: ECT-VGA
; This file contains the panel capabilities description.
; Warning: this file cannot be modified!
; Modifications to this file will not change the panel capabilities and wrong information
; will be sent to Designer package.
[Model]
MfgCode = 65
DisplayOrder = 0
ModelName = ECT-VGA
Description = VGA STN Color 30x80
[Display]
DisplayCode = 16
TouchScreenSupport = 0|1:1
TouchScreenType = 8
PanelKeys = F1-F8,HELP,ENTER
[Attributes]
; Memory Definition
PanelMemory = "2 MB";63 | "4 MB";127 | "8 MB";255 | "16 MBytes";511 | "32 MBytes";1023 : 4
InternalProjectMemory = 736;22 | 736;22 | 736;22 | 736;22 | 736;22 : 4
BlockSize = 32K;0 | 32K;0 | 32K;0 | 32K;0 | 32K;0 : 4
MemoryType = SSFDC;1
RecipeSize = 32 KByte
RecipeSizeNetwork = 32 KByte
AvailableAlarms = 1024
EventListSize = 1024
HardwareClock = 1
PrinterPort = 1
AuxPort = 1
OOTCSupport = 0
Buzzer = 0|1:1
CommErrorPageSupport = 0|1:0
CmdTimeOutSupport = 0|1:0
DataTimeOutSupport = 0|1:0
FieldSelTimeOutSupport = 0|1:0
ScreenSaverSupport = 0|1:0
PasswordSupport = 0|1:0
UniNetSupport = 0|1:0
RTCSynchSupport = 0|1:0
; External Devices
ExternalKeyboard = None;0 | ET-F;1 | ET-Y;2 : 0
ExternalKeyboardBmp = None | ET-F.BMP| ET-X.BMP : 0
TCMModule = None;0 | TCM01;1 | TCM07;7 | TCM08;8 | TCM03;3:0
RemoteIO = None;0
TcpIpSupport = 0|1:0
; Pass Through
HWPassthroughSupport = 1
RemoteHWPassthroughSupport = 1
Versions = v0410, v0420, v0440, v0444, v0446, v0450, v0500, v0502, v0503, v0511, v0512, v0530, v0531, v0551, v0563, v0565, v0566
[Attributes.v0410]
MultiLanguageSupport = 1
ReportPrintoutSupport = 1
[Attributes.v0420]
OOTCSupport = 1
DisableBatteryLED = 0|1:0
[Attributes.v0440]
; Trend Attributes
TrendSupport = 1
MaxTrendWindowsOnPage = 10
MaxTrendCurvesOnTrendWindows = 10
MaxTrendCurvesOnPage = 20
MaxTrendBuffersOnPage = 20
MemoryForTrends = 20 KBytes
; Instrument Attributes
InstrumentSupport = 1
MaxInstrumentsOnPage = 10
; Downloadable fonts
NiceFontsSupport = 1
TextObjectSupport = 1
; UniOP local variables
MaxNrOfUniOPVariables = 100
; Forth Module
ForthSupport = 0
;Flash Backup properties
RecipeBackupSupport = 0
EventBackupSupport = 0
;Min/Max, A1/A2/B from PLC references
MinMaxReferences = 1
MinMaxRefreshType = 0|1:0
; Min/Max and Old Value on Special Data Entry Page
ExtDataEntrySupport = 0|1:1
[Attributes.v0444]
[Attributes.v0446]
MaxNumBitmaps = 2048
MaxBitmapsIndexTable = 32768
[Attributes.v0450]
;Enhanced operations
PixelSVGZOrderSupport = 0;
ObjectAttributeSupport = 1;
DProtoSupport = 0|1:0;
[Attributes.v0500]
GatewaySupport = 1
[Attributes.v0502]
CmdMenuMacroSupport = 1;
[Attributes.v0503]
[Attributes.v0511]
[Attributes.v0512]
EnhancedAlarmSupport = 1
EnhancedAlarmEventsSupport = 1
EnhancedAlarmColorSupport = 1
[Attributes.v0530]
EthDownloadSupport = 1
[Attributes.v0531]
[Attributes.v0551]
[Attributes.v0563]
ExtNumCyclicDataTfr = 128
[Attributes.v0565]
[Attributes.v0566]
Ahmedtalaat
Hi, need your help i setup the designer 5.07 but when i run it massage coming "this app cant run on your PC"
My HMI etop312 Partnum/ Etop312U101 i need to take backup from this software to transfare on other unite
This is a fully functional installation version. Check compatibility in Windows settings (windows version), since the program is quite old.dekelec wrote: Tue Feb 21, 2023 8:10 am https://www.mediafire.com/file/b23tuhs552s9wn5/UniOP_Designer_5.08.rar/file
