Hello!
Can anyone tell me how to compare application logic of the PLC program either in Ladder or ST or anyother language using Unity Pro XL V4.0?
Lookg forward for your reply.
Regards
Leo-Ali
[?]: Unity Pro - How to Compare Logic of two applications
leofarhan
WH_Mike
Re: [?]: Unity Pro - How to Compare Logic of two application
If you woud like to detailed compare of two projects (application), so it is not possible.
Unity Pro have the tools to only check identical Name, Version and Date of compilation ("Compare") of Project / Application between PC and PLC (Menu->PLC->Compare...) or between PLC Memory and Card (Menu->PLC->Project Bacup...->Backup Compare). It not show you what difference there is, but only equal or not.
Schtiel
Try Unity Dif
This Unity Pro option provides users with the ability to compare two different Unity Pro project files. It generates a report that identifies differences between the two projects. Users can review the generated report on-screen, save the report as a file, or print the report.
WH_Mike
Unity Dif realy work, but show differences of initial values variables in structures without name of certain variable (only name of strucktures).
Differenses in ST language show correct.
Registration makes like here - for Unity Pro - by changing BrickLicenceManager.dll and next registration with any values!
Schtiel,
Schtiel,
Novice
Dear All,
Please can you post the part number for Unity Pro DIFF V2.2
Novice
Thank you so much Schtiel
bobafett
Someone knows how to register unity dif 8.0.
maxx86
Re: [?]: Unity Pro - How to Compare Logic of two applications
UP!
i need to know too. I try with procedure with DekartDisk for Unity Pro XL but it is not good for Unity DIf
