How to edit a new symbol in eplan p8?
thanks
[?]: How to edit a new symbol in eplan p8?
dsekulic
Re: new symbol in eplan
Do the following: Utilities -> Master Data -> Symbol -> New. Then You have to choose in which library You want to create new symbol. You can use existing library or create Your own (Utilities -> Master Data -> Symbol Library -> New). Then choose which variant of symbol You want to create (there are 8 different possible variants of same symbol - related to orientation). Afterward You choose symbol name and function definition. Now You can create Your own symbol.
regards
regards
oaie
Re: [?]: How to edit a new symbol in eplan p8?
hi
but how to save the new symbol to be used later?
and where is saved?
many thanks
and where is saved?
many thanks
dsekulic
You have to specify wright directory in Options -> Settings -> User -> Management -> Directories. Under Symbol You need to put appropriate path to Your symbol libraries.
regards
regards
oaie
Thank you very much!
one question:How do I new device ant haw save it?
thanks again
thanks again
