I planned finalize high level HMI interface using WinCC project.
I need system that can connect with S7 200 controllers. WinCC with such controllers works only via OPC server, but I can`t
come over such problem as big delay reading tags using such OPC server as PC Access, when some of PLC was not in work.
I choose WinCC Flexible (after special testing exactly with such condition, WinCC flexible not show such behavior, as WinCC &
PC Access together).
But I have problem using WinCC Flexible. Problem connected with choosing screen resolution.
Before I planned realization with WinCC, and my wide screened computer monitor not was a problem.
How can I sets settings in WinCC Flexible for non-standard screen resolution? as variant for 1440х900 screen resolution.
Thank you.
[?+]: WinCC Flexible 2008 SP2 support wide screens
Netik
Re: WinCC Flexible 2008. Not standart resolution...
viewtopic.php?f=36&t=8650
WinCC flexible 2008 SP2
What's new in WinCC flexible 2008 SP2? wrote: Widescreen for PC Runtime
* 1440 x 900, 1680 x 1050, 1920 x 1080, 1920 x 1200
Netik
Thank you very much!CoMod wrote:viewtopic.php?f=36&t=8650
WinCC flexible 2008 SP2What's new in WinCC flexible 2008 SP2? wrote: Widescreen for PC Runtime
Homeroid_BL
Re: [?+]: WinCC Flexible 2008 SP2 support wide screens
You can connect S7-200 to WinCC Flex via MPI (I did it, using USB/Multimaster cable and PC-Adapter, both cables work.) Works also on the MPI network.
Netik
Connection that I use was MPI. All my plc works via MPI connection.
For such task I use standard Profibus/MPI card with PCI interface.
