[?]: No configuration I/O 1756 module emulate
cuongvcs
Post by cuongvcs »
I configuration I/O module with 1756 module, but after selection new module ,it dose not appear to frame their choise name, slot,connect parameters....etc.
and displays module fault.diplays properties not ok
please help me. thank
dehell
Re: No configuration I/O 1756 module emulate
Post by dehell »
Which software?
Give us a copy screen, it will be more easy to help you!!
Best regards.
acaua
Post by acaua »
Hello, I also fail to emulate in my 1756-L61 CPU in RSLogix Emulator 5000 v17. Is there any way to emulate all my existing project? I wish to analise off-line an application that is running on the PLC. In my emulator I've only a EMULOGIX 5868 controller and I could't install my CPU and cards. Is it possible?
dehell
Post by dehell »
RS Emulate support only EMULOGIX 5868 controller and digital I/O cards (simulation cards).
Analog or other exotic module are not available. For analog testing, you have to create simulation routine.
Remenber :you have to create your project with EMULOGIX 5868 controller .
If you want to create digital I/O modules, take care of the data size for the backplane.
Read the help of the software.
Best regards
