MY OMRON HMI NS10TV00 V2 Touch screen's touch system do not work.
So i cant run my machine
What is the Problem?
is there any way to run plc without HMI?
i heard about NS- Runtime & CX- Supervisor this software can run plc without a HMI.
it uses PC as a HMI
Now how can i do it?
i download cx supervisor but i dont know how to do that?
PLEASE HELP
[?]: OMRON HMI NS10TV00 V2 Touch screen not work
isteak007
Homeroid_BL
Re: [?]: OMRON HMI NS10TV00 V2 Touch screen not work
Download CX-One.Here you will find CX-Designer included.
In order to control your machine from PC, you will need source project for NS10. Generaly, PLC can normaly run WITHOUT HMI connected (in most cases PLC does not knw if HMI is connected at all), but, you are not able to change parameters and issue commands to machine.
isteak007
I have Source Project but i dont know how can run my machine with cx designer.
do you know How to do it?
Homeroid_BL
Open project.
Then Tools/Test/Connect to PLC
Chooose network (works with hostlink ONLY!!!)
isteak007
Thank You For your reply
Do i need any special Cable?
or cable that used in plc to hmi.
Thank You
Thank You
Homeroid_BL
You need a PC-PLC cable (cable for CX-Programmer, to connect to PLC)!!!
