I need your help on key for Simatic WinCC 6.0, it's quite old so Simatic_ekb_install of 2008, 2009 and even 2010 i've tried doesn't work out. Is there any tool like ekb_install should be used for WinCC 6.0, mine is: Simatic WinCC K6.0.2.0
[?]: WinCC 6.0 Key
Akachi
[?]: WinCC 6.0 Key
Hello all
Re: WinCC 6.0 Key
Try Siemens.exe from
viewtopic.php?f=30&t=218&p=508#p508
Sim_EKB_2006_11_14a.zip
[dead] :/270087658/S ... 11_14a.zip
Akachi
Re: WinCC 6.0 Key
Thanks CoMod, i'd already downloaded Sim_EKB_2006_11_14a.zip as your mentioned, but when decompress the archive there's a lot of *.EKB file inside "WinCC 6.0" folder - and i try file-to-file put it in C:\AX NF ZZ, restarting WinCC and there's still "DEMO" license i got.
Would you please go detail on this issue, thank you for your effort.
Best regards,
Akachi
Best regards,
Akachi
Re: WinCC 6.0 Key
Need info from C:\Program Files\Siemens\WINCC\diagnoseAkachi wrote:Thanks CoMod, i'd already downloaded Sim_EKB_2006_11_14a.zip as your mentioned, but when decompress the archive there's a lot of *.EKB file inside "WinCC 6.0" folder - and i try file-to-file put it in C:\AX NF ZZ, restarting WinCC and there's still "DEMO" license i got.
List of installed keys from C:\AX NF ZZ (hidden system folder)
Screenshot of AuthorsW or ALM
Akachi
Re: WinCC 6.0 Key
1. Please refer attachment for detail on "C:\program files\Siemens\WinCC\Diagnose"
http://www.mediafire.com/download.php?pdvfyk3bpa8za06
2. List of installed keys from C:\AX NF ZZ (hidden system folder):
S7PROF54.EKB
S7PROF54.HRD
A9IDB360.ekb
A9WLB160.ekb
A9WNC160.ekb
A9WOP160.ekb
3. Screenshots:
WinCC:
ALM:
Please right-click to image and show picture for full image, i think forum have a script not to show picture auto-resize to fit
Re: WinCC 6.0 Key
See viewtopic.php?f=4&t=11415
for v7.0 keyname without SI*L prefix
Minimal keyset (example for v7.0)
You need install ONLY 1 RC key - A9WRC*60.EKB .
In this example only low 128 Tags key is worked - others keys is banned !!!
Akachi
Re: [?]: WinCC 6.0 Key
Sorry CoMod, but i'm really hard to understand what are you talking about. Would you please give me some more detail on this!?
You need to installLicense.Log wrote:07/19/2010 13:03:52 Control Center - Demo Mode ConfigurationSystem enabled -
07/19/2010 13:03:52 NoLicense CS | Name of License = A9WRC260 | Text of License = | Exists = No |
A9WRC460.EKB WINCC-V6 RC 64K PTg 512 ATg
A1WPC412.EKB WINCC Chipcard
A9WSEC60.EKB WINCC Server
A9WC2460.EKB ... and others Intreface EKB
[URL=http://img293.spamm.us/img293/1333/keysetforwincc.gif][IMG]http://img293.spamm.us/img293/1333/keysetforwincc.th.gif[/IMG][/URL]-
Akachi
Hi Mr CoMod, i still stuck there, try to install keys but it just shows "DEMO". I didn't install interface EKB yet, waiting it gets out of "DEMO" first. Please give me your comments on this issue
I can't help without infoAkachi wrote:i still stuck there, try to install keys but it just shows "DEMO". I didn't install interface EKB yet, waiting it gets out of "DEMO" first. Please give me your comments on this issue
Full info need.
Windows, PC Hardware, ...
what wrote License.Log ?
Possible WinCC 6.0 SP2 incompatible with ALM.License.Log wrote:07/19/2010 13:03:52 Control Center - Demo Mode ConfigurationSystem enabled -
Use AutorsW.
Akachi
Thank you CoMod,
System using Windows XP SP3, installing on IBM T42 Laptop.
07/23/2010 21:56:35 DemoVersion
07/23/2010 21:56:35 Control Center - Demo Mode ConfigurationSystem enabled -
07/23/2010 21:56:35 NoLicense CS | Name of License = A9WRC460 | Text of License = | Exists = No |
07/23/2010 21:56:35 InitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = A9WRC460 | Text of License = |
07/23/2010 21:56:35 NoLicense ED | Name of License = A9WRC460 | Text of License = | Exists = No |
07/23/2010 21:56:35 Control Center - Demo Mode Editors enabled -
07/23/2010 21:56:35 InitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | NameForMessageBox = | Name of License = A9WRC460 | Text of License = |
07/23/2010 21:56:57 Control Center - Demo Mode ConfigurationSystem enabled -
07/23/2010 21:56:58 DemoVersion
07/23/2010 21:56:58 InitLicense CS | AppName = AppCS:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = A9WRC460 | Text of License = |
