[?]: Wonderware Application Server Deployment Problem
af.naderi
Post by af.naderi »
Hi every body,
I work with a galaxy that contains two winplatform. one of them is server and the other one is client.
I set server settings base on my own computer and deploy it easy.
But when i confige client setting base on other computer and deploy it, WAS does not deploy it.
Could anyone help me?
Please describe me step by step.
Roman
Re: [?]: Wonderware Application Server Deployment Problem
Post by Roman »
1 On client side you must install bootstrap
2 Command PING ClientName must work on server side. Not PING IpClient
DelSnos
Post by DelSnos »
af.naderi wrote:Hi every body,
1. On the client computer should be installed bootstrap. (IAS component)
2. On a server and on the client computer should be created an identical account (start/prog/Wonderware/common/Change Network account/)
Rus
1. На клиентской машине должен быть установлен компонент IAS bootstrap.
2. У сервера и клиентской машины должны быть созданные одинаковые аккаунты, через утилитку Change Network account. Внимание, потребуется перезагрузка PC! (start/prog/Wonderware/common/Change Network account)
