[?]: CPU313 upload error from step7 v5.4+sp3
maher
Post by maher »
Hi
I have siemens cpu 313 with MC flash card , when i tried to upload the program the following message appeared :
step7 message wrote:UPLOAD STATION TO PG ( 13:44 )
ONLINE CPU TYPE 6SE7313-1AD03-0AB0 V1.0.0 UNKNOWN.
The software which i used is simatic manager step7 v5.4+sp3
So what does it mean and what can i do ?
please urgently
best regards
Maher
Re: [?]: CPU313 upload error from step7 v5.4+sp3
http://support.automation.siemens.com/W ... en/4067792
SIMATIC S7-300, CPU 313 CPU WITH INTEGRATED 24V DC POWER SUPPLY 12 KBYTE WORKING MEMORY
Product cancellation 2004-10-01
No programm inside ?
Umencho
Post by Umencho »
maher
Post by maher »
thanks a lot
i will check these procedures
thank you very much
Maher
maher
Post by maher »
Umencho wrote:Or look at http://www.automation.siemens.com/WW/fo ... anguage=en
Best regards,
Umencho
Hallo
according to your link i decided to upgrade my software from V5.4+SP3 to V5.4+SP5
but after loading the service back file SP5 from the siemens site ( SIMATIC_S7_STEP7_V54_SP5.zip ) and installing it now, i have two shortcut icons for simatic program and also two shortcut icons for Automation License Manager .
but when i try to run the simatic manager program the follwing message was appeared
[THE AUTOMATION LICENSE MANAGER SERVICE HAS NOT BEEN STARTED PLEASE START THE SERVICE
and the program is not working any more
what is happened ? why , why why ?
please help me (h) (h) (h) (h)
please
Maher
FAQ wrote:Some drivers of software products, in particular mobile telephone software (to date Mobile Connect software products) are not compatible with the communication mechanism of the Automation License Manager (ALM)
Right button on My Computer
Manage>Services and Application>Services > ALM service
or install ALM v4
maher
Post by maher »
Thank you very much Mr. comod
now the new software version is running .
thanks a lot
Best regards
Maher
maher
Post by maher »
Hi
The steps for uploading :
I tried to upload the program from the cpu 313 with MC flash card but the result as before
( UPLOAD STATION TO PG ( 13:44 )
ONLINE CPU TYPE 6SE7313-1AD03-0AB0 V1.0.0 UNKNOWN. )
BUT when i go to online without uploading no problem happened and also i can make downloading the program , after that the uploading process is not allowed
also i downloaded the HW configuration but noway to upload it.
and when i tried to delete the MC flash this error would appear
( open 33:8570 )
EPROM: THE PROGRAMMING INTERFACE OR THE EXTERNAL PROMMER IS ALREADY BEING USED BY ANOTHER APPLICATION.
Best regards
Maher
