[?]: How to upload from HMI Plusview 1250 to PC
hanhdong162
Post by hanhdong162 »
Hi All
Please show me how to upload program from HMI Plusview 1250 Alen Bradley to My computer. And down load file backup from My computer to HMI Plusview 1250.
I don't have document. Please share document for me
Thanks a lot! (pgood)
Serge_n
Re: [?]: How to upload from HMI Plusview 1250 to PC
Post by Serge_n »
hanhdong162
Thanks very much!
But I don't know what software to use upload/download file application from HMI to Mycomputer. How to download/upload or transfer.
Thanks (pgood)
dehell
Post by dehell »
You need Factory Talk view studio ME (machine edition) for upload or download a file between your PC and the panel view.
Best regards
Ryzhij
Post by Ryzhij »
If your PanelViewPlus device has the CF-card it's may be easy. ;)
cuongvcs
Post by cuongvcs »
hanhdong162 wrote
Hi All
i use USB for transfer Application to HMI plusview 1250 and upload it.
hanhdong162
Thanks every body to help me.
I find to the software Factory talk view studio Machine Edition CPR9 V5.0. Thought, I share for every body to use.
Link download: http://www.mediafire.com/download.php?y3tmvzltydjyjul
But I don't know configuration connect HMI to My computer by USB or Serial Com port for upload.
I did:
(I connect with HMI by Serial Com port)
1. On the Windows Start menu, select Programs, Rockwell Software, and then click
FactoryTalk View ME Station.
The FactoryTalk View ME Station dialog box opens.
In the FactoryTalk View ME Station dialog box, click Terminal Settings.
2. In the FactoryTalk View ME Station dialog box, click Terminal Settings.
3. Double-click Networks and Communications.
4. In the Networks and Communications dialog box, double-click RSLinx Enterprise
Communications.
5. Click the Serial-DF1 driver, and then click Edit Driver.
6. Select Use Auto-Configuration, and then click Edit.
7. In the dialog box that opens, select Yes, and then click OK.
Auto configuration works with most devices, including Logix5000 and PLC-5®. If
auto configuration is not successful for your device, return to these steps, select No,
and continue to step 7.
8. Set up the driver, and then click OK. If you are using auto configuration, skip this step.
And then I upload:
To start the Transfer Utility tool
1. On the development computer, do one of the following:
+ In FactoryTalk View Studio, on the Tools menu, click Transfer Utility.
+ On the Windows Start menu, select Programs, Rockwell Software, FactoryTalk
View, Tools, and then click ME Transfer Utility.
2. But I click transfer happen: valid device
Please show me detail and attach document
Thanks and best regard!
(pgood)
