How to do this right? Is this possible in general?
When OP is integrated in PCS7-project (v. 7.1) problem with OS occurs:
1 In NetPro - "... s7omwinx.dll... could not be loaded";
2 In HW Config - cannot insert WinCC App. The same message about s7omwinx. Sometimes insertion is sucsessful after restart Manager, but this is not systematically.
3 When starting WinCC Explorer - MCP_CS.dll and CCMCP_MT.dll also could not be loaded.
4 When activating project - ccaeprovider.exe memory error, but runtime is somehow starting.
There are no such a problem when step7-project is created (when in newly created project properties I select "Use: STEP7" instead of "...PCS7").
[?+]: Wincc Flex 2008 integration in pcs7-project
thed
Re: [?]: Wincc Flex 2008 integration in pcs7-project
i have pcs7 v5 & protool panels into project without any problem
v7.1 ... what your OS? localised?version of flex?
normaly it`s not bug of pcs.TIA ideology does not allow such bug
thed
OS - winXP SP3 EN, WinCC Flexible 2008 HF1
I've downloaded free library from Siemens "WaterLibrary". An example project is delivered with it. Tomorrow I shall look this project, if I've understood correctly in this project an OP was integrated. And may be I'll find a solution
Some users also reported about a similar bug (on different forums), but there was no solution. There was suggestions to reinstall SQL, WinCC etc. but it's no use...
thed
There's no OP in the demo project...
They've connected OP by global DB. So, with PCS7 this is the only way and no integration is possible? But then what about this? In this manual OP is integrated, I've made according to this tutorial but problems are the same...
thed
I've installed PCS7 7.1 SP1 and WinCC Flex 2008 SP1. According to the compatibility table this combination must work, but one problem with s7omwinx.dll still remains
thed
1-st step: create a separate project (not in a multiproject) with panel (for example, OP77B).
2-nd step: create a multiproject with a project in which an OS is inserted.
3-rd step: insert a project with OP in multiproject with OS.
Only this sequence works. Correct me if I've made a mistake.
And note: in order to PCS7 and WinCC Flex working together (including OP integration) PCS7 must be v.7.1 SP1 and WinCC Flex must be 2008 SP1 (in my case 2008 SP2 also works).
