Hi friends
I am trying to save a program in a SLC500 5/04 EEPROM,I have put a 1747-M13 in the CPU but when I try to store the program (Comms, EEPROM, Store To EEPROM, this message appears:
StoreToEeprom Failed: 0x4
I have 8.10.00 (CPR 9) RSLogix500Software
and 1747-L542C 5/04 CPU 32K Mem. OS401 Series C FRN 3-8
Do you know how to fix this problem?
Thanks in advance.
[?]: SLC500 5/04 StoreToEeprom Failed: 0x4
asteroidehk
asteroidehk
Re: [?]: SLC500 5/04 StoreToEeprom Failed: 0x4
Hi friends
Nobody knows how to fix this problem?
Also i have tried with a new memory module and the same error appears.
I have RSLogix 500 8.30
Thanks in advance
Thanks in advance
Have you check the jumper on CPU card?
Best regards.
Best regards.
asteroidehk
Hi
This CPU hasn´t jumper for the eeprom.
The jumper j4 is only to protect operating system download.
Is this correct?
Another idea?
Best Regards
Is this correct?
Another idea?
Best Regards
