Hi all,
I wanted to refer a DB address for example DB121DBD2.0;
How can filter this item in cross reference filter .
all help appreciated
Thanks in advance
[?]: Cross referance filter to refer a DB address
dspic
Re: Cross referance help
DB121.DBD2 or DB121.DBX2.0
cross reference filter only with DB121
but you can use "go to location" on your variable
dspic
THANK YOU VERY MUCH.
If you never mind i wanted to know one more thing.
DB120dbd12.0 .
how i can find location of this address reference in entire the program .I tried the filter in DB120 but is not showing in the reference list
DB120dbd12.0 .
bond
Re: [?]: Cross referance filter to refer a DB address
Incorrect: *DB120
Must be only number: 121
dspic
