thanks in advance
[?]: How to use C language in Siemens PLC programming ?
thanks in advance
thanks in advance
Re: How to use C language in Siemens PLC programming
thats is also my question,how to do...
It is not possible, see this thread:
http://www.automation.siemens.com/WW/fo ... ostID=5147
Actually, there is no need in C, you can use SCL instead.
automation specialist never made good computer specialist, and computer specialist never made good automation specialist,
you can not use C language in PLC programming. though you can use it in Wincc , but you must aware with the fact that Siemens use its own customized Header Files. you can create your own Header File through MS Visual Studio.
Why don't You try S7-SCL if You need more than STL. This is Pascal like programming language.
regards
regards
Re: [?]: How to use C language in Siemens PLC programming ?
You use Siemens soft PLC WinAC with their ODK.
Then you can write functions in C and call them from the step7 code.
/steff
/steff
