Hi all
i have the ( drive monitor 5.4 sp1 ) software and i need the specification for the communication cable between simovert drive and my copmuter .
also i need the procedures to upload the parameters from the drive & the steps to download the parameters to the drives
best regards
MAHER
[?]: pin out for cable of drive monitor 5.4 and simovert
maher
venix
Re: [?]: pin out for cable of drive monitor 5.4 and simovert
Hello!
The cable is a DB9 male(Simovert) - DB9 Female(computer)
pin8 - pin 2
pin2 - pin 3
pin 5- pin 5
chassis ground- chassis ground
Best regards!
Venix
pin8 - pin 2
pin2 - pin 3
pin 5- pin 5
Best regards!
Venix
maher
Hallo
i need the pin out also for the connection between the PC & MASTERDRIVE MC
regards
Maher
regards
Maher
Umencho
Hello Maher,
You could find pin's description in MC Compendium.
( http://support.automation.siemens.com/W ... n/13472407 ).
Basically cables are the same with VC.
BR
BR
