Is it possible to export a 2 different project and import to a new single project?
for example..a sample project with AS-i diagnostic and another project with PROFIBUS diagnostic and i want to combine it into one project...so instead of making new tag list,alarm list, etc can i simply import those 2 different sample project into a new project?
[?]: 2 HMI project combined to single project
ryanbestgarcia
Re: [?]: 2 HMI project combined to single project
It is not possible!
But you can use WinCC Configuration Tool to do that. You can make Excel workbook with configuration of one project. Then store it. Next open the other project and copy/paste the structures/tags etc. Then write changes only into the project. Pictures and function you can copy manually as files.
Good lack!
Good lack!
