[?]: How can i find or set a MB time base pulses for s7-300?
melvinr27
Post by melvinr27 »
Hello there, i am trying to find or set a memory bite (MB) of time base, for s7-300, i saw one time on other programs using plcsim, a MB running like a location for the the time base, i tryed to find the fix or the condition in this program but never have successfully, later i try to program but not works, how can i set or define this memory area? (oo)
Alexsan
Re: How can i find or set a MB time base pulses for s7-300?
Post by Alexsan »
You need to set this memory area.
Open Hardware config, double click on your CPU module, select tab CYCLE\CLOCK MEMORY, and check CLOCK MEMORY option. In this section, you set the Memory area number you need.
Regards
melvinr27
Post by melvinr27 »
very good... :mrgreen:
(tyou)
mario_fides
Re: [?]: How can i find or set a MB time base pulses for s7-
Post by mario_fides »
Goog explanation
