tanks
[?]: pin out cable control tecnique (Emerson)
mario_ingen
I need to know if the communication cable to control drive tecnique (Emerson) is a converter 485 or it is and if protocolarizado and if they have the programming cable pinout communication.
tanks
tanks
jigmi
Re: [?]: pin out cable control tecnique (Emerson)
Hi mario_ingen
What's model or type do you want?
I have now Commander Sk and Unidrive SP is use RS-485 protocal port RJ-45.
Detail pin :
1 = Terminal resistor (120 ohm)
2 = Rx,Tx
3 = 0V
4 = +24V
5 = N.C.
6 = Tx Enable
7 = Rx\,Tx\
8 = Link to pin 1
You can use pin 2,3,7 for RS-485 converter for programming it.
Good luck,
Jigmi.
Detail pin :
2 = Rx,Tx
3 = 0V
4 = +24V
5 = N.C.
6 = Tx Enable
7 = Rx\,Tx\
8 = Link to pin 1
Good luck,
Jigmi.
