Hi everybody... I've recently read this topic abount emulating Spac Automazione 2009 dongle.
http://www.plcforum.uz.ua/viewtopic.php?f=7&t=10379
Thanks to all. This also works for me. I managed to run Automazione2009 succesfully.
I also have a similar problem with SPAC Impianti 2008.
I've got an Eutron Smartkey 3 USB NET with several licenses of both Impianti2008 and Automazione2009 inside.
What I would try to do is:
- Emulate this key OR
- Get a dump of a Spac Impianti 2008 single license dongle from somebody else...
Would be nice if you could provide me a keygen for both Spac Automazione 2009 and Spac Impianti 2008 working with my dongle, so I can run Automazione 2009 and Impianti 2008 with only one driver (like when I use the original dongle...)
Here is the file I obtained following this steps:
- used EU_PBL.exe to get eutron.dmp
- used "MAKE_EMUL.exe eutron.dmp" to get eutron.sys
- rename it in LicSpacImp.sys to avoid confusion
- replace all instances of "eutron" with "LicSpacImp" in install.bat
[dead] :/391423856/Simp08.zip.html
Then I launched install.bat and restarted the machine
The Key is correctly recognized by Test32.exe and LicMgr.exe (see the \Key Utility folder on DVD) and but I'm having the same problem explained in other topic's posts: my original seral number is no more accepted by the setup.
Here is the SPAC Impianti 2008 full package ISO download link:
http://www.sdproget.it/software/SPAC_Im ... 2008_3.zip
Any help is appreciated.
[?+] Emulator for Spac Impianti 2008
BrokenLeg50
Re: [?+] Emulator for Spac Impianti 2008
for Eutron Smartkey emulator Details https://dongleemulator.com/eutron-smartkey-emulator/
