Hi every body,
i install CITECT SCADA Ver.7 and want to connect to SIEMENS S7-315 2DP PLC.
Please anyone descibe me step by step.
[?]: connect CITECT SCADA to SIEMENS PLC
Re: [?]: connect CITECT SCADA to SIEMENS PLC
The best option is to use as a server kepware opt to acquire data from PLC, both the serial port as ethernet, and configure Citect to access data through kepware
hi jlcoloma,Thanks for your guide, but my problem is that i don't know how can do it.
Citect is not user friendly, and i don't know difrence between board, IO Device, ...
if it is posible, please explain me how can use kepware or siemens ethernet driver to do that.
Thanks a lot
Thanks a lot
hi every body,
Could anyone help me ?
You must install "Simatic Net" your computer for communication. (Simatic Net V6.0; V6.05; V6.1 or V6.2 for Win XP)
You look "Citect Help / Driver Help / S7 Driver / MPI- Profibus {or } TCP/IP Config" for Configration settings;
Use PCDirect Driver:af.naderi wrote:hi every body,
[dead] :/458157547/I ... Siemens.7z
I check and work with it personally!
