who know please explain me, what is difference, advantage and disadvantage between 2 software
[?]: What's the difference between WinCC Flexible and WinCC
carlo1975
I don't know & use WinCC Flexible or WinCC .
Re: differenceWinCC Flexible or WinCC
See http://www.automation.siemens.com/mcms/ ... fault.aspx
About WinCC wrote:PC-based process visualization
The SCADA (Supervisory Control and Data Aquisition) system SIMATIC WinCC establishes a basis for Plant Intelligence solutions.
WinCC is able to acquire and archive process data, which can be aggregated, analyzed and sent to MES-systems for further processing using the WinCC Plant Intelligence options.
Scalable process-visualization system with numerous high-performance functions for monitoring very big automated processes (256 000 tags + long tags archive in SQL format).
Whether in a single-user system or a distributed multi-user system with redundant servers, the system offers complete functionality for all industries and features optimum openness.
About WinCC flexible wrote:WinCC flexible = ex ProTool. Panels based process visualization.
HMI software for flexible implementation in machine-oriented and process-oriented applications, across all industries:
From micro panels right to multifunction panels MP377 (max 2046 tags with small tags archive in Excel exchage format) and WinCC flexible Runtime PC (max 4092 tags).
carlo1975
Re: [?]: What's the difference between WinCC Flexible and Wi
Thank you very much for your answer.
