I don't know how use WinCC flexible 2008 link with S7-PLCSIM ,if somebady know that pls share it, thanks a lot!
[?+]: How to use WinCC flexible 2008 link with S7-PLCSIM?
				iop_p
Hi all,
				dsekulic
Re: How to use WinCC flexible 2008 link with S7-PLCSIM?
It is the same as with real PLC. In following link You can see what You have to do. Then start PLCSIM (change connection to PLCSIM(PROFIBUS)), start runtime in WinCC Flex, and You can to simulate.
Link Sample.zip
[dead] :/385373562/Sample.zip
My version or Step7 is 5.4 + SP4 and WinCC Flex is 2008 SP1 + HF2
regards
Link Sample.zip
regards
				iop_p
Thank you very much, it works now
