i have a camera ip .
and insert to wincc use internet explore , if run on my Pc it's ok , but i use web navigator it's don't work , anyone can help me ?
and can help me how to setup a system redundancy , i use two pc connect via Lan network , WinCC version 7.0
[?]: Camera IP and WinCC web navigator v7?
nglong
lopof
Re: [?]: Camera IP and WinCC web navigator v7?
You must register OCX control (of IP Camera) to computer with Webnavigator client.
I use this solution and works fine!
nglong
thank you. i'll to test itlopof wrote:You must register OCX control (of IP Camera) to computer with Webnavigator client.
nglong
i can't do it , in WinCC Graphics i use WinCC Web Control , at Address is Camera' IP
and use Webnavigator Web view publisher , in client i have register Web control ActiveX , it run ok on my Pc but at Pc Web navigator client have problem here
i use ActiveX of Camera but i can't change IP, Mask, Gateway , port.....
please tell me more about your project ..
