Dear Friends ,
I have very urgent requirerment.
I want schematic diagram of IM cable 721( Used to connect IM304 & IM 314 AND FOR Im 314 & IM463-3 of S7) .
I need this cable for S5 to S7 conversion.
Details of this cabel are in the manual of S5 and S7 under the interface module sections. ( S7400 automation system module data -S5 interface Ch No. 7 , page no. 372 ,of manual A5E00850736-06).
But they are bit confusing. It is not clearly mentioned types of 50 pin connectors ( male or female) further pinouts of connectors are diff from the standard 50 pin connectors.
Particularly pin nos of left hand connector are very confusing as they do match either with male or female stanadard 50 pin d connector.
Your help in htis regard will be very helpful Thanks in advance.
Regards
Amit
[?]: IM 721 cable schematic diagram ?
amit
