hi frnd,
i am using Sinamics cu320 on Cpu 314c-2dp.
when i am optimize with encoder(smc30) then i got fault no. 7900" motor locked" at no load.
why this fault occure.
if some one gave steps for optimize then hepl me.
thank you...
[?]: sinamics cu320 with encoder problem
rahul
Scarch
Re: sinamics problem
Optimize first the current loop... and much better if you forget Siemens when we talk about drives.
rahul
Re: [?]: sinamics cu320 with encoder problem
hi frnd...
this problem solve in single drive...due to torque limit...
now in my 2nd drive i got F1910 profibus setpoint error...
but my 1st drive is ok...
so some gone through this fault...
thank you...
thank you...
pacojones8
Could you attach your project or material list.
Are you working in servo or vector mode?
Which profibus telegram are you using?
