Hi everybody!!
I install iFix5.0 with SP1 and SP2 ,but don't find Modbus-TCP drivers for it.
I want to connect it to PLC Wago 750-841.
I fond some links in viewtopic.php?f=46&t=5972 but this drivers for version 4. I think this drivers approach for v5.0, but not assure .
Where download drivers for v5.0 and how install it ?
[?]: Modbus-TCP drivers-“MBE" for iFix 5.0
rafal61
Re: [?]: Modbus-TCP drivers-“MBE" for iFix 5.0
Hello!
You can contact to your local distributor of iFIX it's free, but if you don't want to do it just download from:
Installation is simple: unzip and then run setup.exe it will install and you will be able to add it in iFIX.
I've tried it with iFIX5.0 with SP2 and it works like a charm.
Best regards
Rafal61
http://www.mediafire.com/?zzdywmjzl0tI've tried it with iFIX5.0 with SP2 and it works like a charm.
Best regards
Rafal61
BladeMaster
Hi, Rafal61rafal61 wrote:Hello!Rafal61Code: Select all
Thank for sharing. But i downloaded your link, and it's MB1 Driver, not MBE.
Please give me Modbus Ethernet v7.xx "MBE",
I'm just a student
heavenbird
you can use IGS driver by GE.it is free ,if you have licence for ifix
