[?]: Create equal to SV timer
I need to use about 750 SV timers, how can I simulate them? No way with IEC timers or sfc blocks, some idea? Only SV is valid for my application
Re: [?]: Create equal to SV timer
U #i // bool start timer
FP #ib // buffer static or in out (bool )
SPBN weit
L #v // value for timer
T #c // timer
weit: L #c
L 1 // timer = timer - 1 call in time constant ob
-I
T #c
L #c // if timer not run out then timer output = 1
L 0
<=I
SPBN wei2
L 0
T #c
SET
= #r // r = result
SPA sege
CLR
= #r
sege: NOP 0
Hi!
Why can't you use the IEC funktion SFB3 "TP"? It should work.
sventek
sventek
Thanks but... Moving, I do not have very clear the type of the temporal fields (in, out, temp, etc) and wei2 jump is not defined. Sventek, I have downloaded the SFB3 it is a timer but dont know how to use it as a SV timer....please help
Hi search!
When the SFB 3 is in the Simatic Manager, mark the block and press F1 for help. Everything you need is in there. I'm sure you can use it for a SV timer.
regards
sventek
regards
sventek
No, definitely is not possible to use it as SV. The SV restarts everytime the input changes from 0 to 1, but this one keeps running until the time has expired and then goes to zero even if the input is 1.
Thanks anyway
Thanks anyway
Hi search!
Ok, you'r right. But i made a small programm to simulate a sv timer. Please download, unpack and call the FB1 as shown in OB1. I've tested and it seems to work.
[dead] :/370851157/Test_sv.zip
regards
sventek
regards
sventek
Hi sventek,
Thank you very much it works very well... I didn't know it was possible to include TON timers in the temporal variables
Thanks again
Thanks again
