I want to install ProTool Pro 6 SP 3 onto my pc, Step 7 5.4 SP 3 is already installed.
But ProTool refuses to go intalling, it just halts on the nstall screen.
Does anybody allready experienced this and what is the solution?
Best Regards
Max
[?]: Problem installing ProTool Pro 6 SP 3
Maxime
Re: Problem installing ProTool Pro 6 SP 3
viewtopic.php?f=36&t=5673
Install STANDART version
Maxime
Even if I just start up the install of ProTool Standard, it doesn't work. Do you need to first install ProTool and then Step7?
Best Regards
Max
Best Regards
Max
Maxime
I reinstalled Windows and on a clean installation ProTool never refuses to be installed.
It's solved but quite radically.
Thx for the links!
Thx for the links!
toos tablo
hi
please fist remove the simatic family software then the restart system
ofter restarting system instal protool sp3 & then install simatic family software
wsk2009
Hi! I've also problem during the installation. Installation starts, but a moment after start, after "checking the files", appear window with no options, anly button [finish]. I 've installed TIA11, STEP5.5 and WinCC 8 on XP SP3. Have anybody got any idea? I'dont want to reinstall everything.
Corosop15
Hello wsk2009,
I think then you have no chance to install ProTool after TIA.
Greetz
Corosop15
Greetz
Corosop15
FcoBecerra
Re: [?]: Problem installing ProTool Pro 6 SP 3
Hi there! i have TIA installed, step 7, step 5 and wincc 08 and i could install protool pro 6 sp3. I installed from cd, mount the files on cd and run from it. It works for me.
