[?]: How to scale Analog I/O
CX-One, CX programmer, NTST, Syswin ....
Walid Elshazly
Post by Walid Elshazly »
Hello All Friends ,
I need any one to help me to know how to scale Analog I/O in Omron PLcs By CX-One ,
From CX-one Analog configuration I found that The Conversion value of A/I is stored in (for Example) CIO 2001 For The 1st Channel in the First Analog Module . and there is Min and Max Values For the converted Value ( For 15 Bit Resolution) -32768 to 32767 .
and there is settings for Conversion Time / Resolution settings that May be 1ms/4000 Or 250us/8000
as that , I want to ask ....... if I have an analog Signal 4-20mA , The active Resolution Will be 1/32768 or 1/4000,8000 , .......???
What is the conversion of The max value 20 mA ........????
2^resolution ( 32768 ) OR selected from 4000,8000 :?: :?: :?:
and If it will be one .... what the other mean and use.......????
Regards,
