[?] Activation RsLogix 5000 win7
oxykill
Post by oxykill »
Hello all, i tried to activate rslogix 5000 in win7, but i'm not able to mount the .imz file because i cannot mount this image with vitual floppy drive ( unable to install and start driver needed )
Someone have an idea ? How can I activate RsLogiX ?
OxYKiLL
emulefan
Re: [?] Activation RsLogix 5000 win7
Post by emulefan »
You need an EVMOVE USB Version.
This is a special EVMOVE USB that will allow you to move your floppy activation to a USB stick drive. Then you can EVMOVE from USB stick drive to a PC that does not have a floppy drive. You still have to have a source floppy, like your laptop.
I will send you a PM
Regards
rbase88
Post by rbase88 »
Why don't you install your rockwell software in a virtual XP pc? You won't have this problem then.
jmnyoung
Post by jmnyoung »
Would you please send me a PM about the special EVMOVE USB that will allow you to move your floppy activation to a USB stick drive?
I am having similar problems.
Thank you in advance, jmnyoung
mrs_oliveira
Post by mrs_oliveira »
emulefan wrote:You need an EVMOVE USB Version.
Regards
Hi You can send the USB activation to me too?
Tanks a lot
olly
Post by olly »
I think you shoud close the uac protect,then virual flopy,and move.
BachPhi
Post by BachPhi »
olly wrote:I think you shoud close the uac protect,then virual flopy,and move.
Seemed to be a good idea, does it work?
sk83
Post by sk83 »
Do You Have try with dekart private disk..... :?
lpfagundes
Post by lpfagundes »
i have the same problem, so i execute the virtualfloopydisk as admin and it works.
peterg70
Post by peterg70 »
Have you or anyone tried this for Windows 7
viewtopic.php?f=12&t=15633
This is the new method of protection.
