anyone knows how to configure/connect a 2AI I 2WIRE ST analog input module?reading is always overflow(32767) but if I measured it I can get a nominal range.
Need it badly!
thanks in advance!
[PDF]: 2 wire analog input module
Re: 2 wire analog input module
http://support.automation.siemens.com/W ... 166/133300
SIMATIC S7-300 S7-300 Module data
(English / 8148 KB)
Edition: 08/2009
http://support.automation.siemens.com/W ... en/8859629
SIMATIC S7-300 SM331; AI 8x12 Bit Getting Started part 1: 4 -20mA
http://support.automation.siemens.com/W ... n/17473828
example https://support.automation.siemens.com/ ... /awl_e.zip
(English / 8148 KB)
Edition: 08/2009
Re: [PDF]: 2 wire analog input module
Connecting 2-wire measuring transducers to analog module 6ES7 331-1KF02-0AB0
http://support.automation.siemens.com/W ... n/18475312
How do you connect a potentiometer to the analog module 6ES7 331-1KF02-0AB0?
http://support.automation.siemens.com/W ... n/17071108
