To reduce time on installations, removing and recharging serials and activations, I did clone my HD. But Surprise, the activations of my Rockwell products remain in the old HD. So..
Loking in the web, I found this solution for delete the Rockwell Activations that were made by EVMOVE.
How to Remove Rockwell Activation
If you are using the disk-based activation (evmode) with Rockwell and AB software,
you can remove all licenses from your machine by deleting the hidden evrsi.sys
file on your computer:
attrib c:\evrsi.sys -S -H -R -A
del c:\evrsi.systhe newer FactoryTalk activation system.
------------------------------------------------[/b]
I don't know if somebody put this case in this forum before!!!
I hope this will be helpful for you.
Kind Regards
pplupe
