[!]: rename TORRENTS.RU to RuTracker.org
O форуме и файлообменниках.
Правила (или почему могут забанить)
Dear users!
BitTorrent tracker Torrents.ru removed to RuTracker.org => http://rutracker.org/forum/index.php
Bonus: There are no raiting restrictions to the end of March
Registration http://plc.net.ru/viewtopic.php?f=2&t=4977
Today (February 18, 2010) "Ru-Center" (Domain Names Registration Center in Russia, www . nic.ru) has suspended domain delegation TORRENTS.RU without warning, and any notice.
According to information from the "Ru-Center", delegating domain TORRENTS.RU was suspended because of order from the Investigative Division of Chertanovskaya Moscow regional prosecutor's office from 16.02.2010"
Corresponding request has been sent to "Ru-Center , however, it is obvious that the clarification would take some time, during which torrents.ru address will not be available.
In this regard, we had to change the domain name to rutracker.org urgently.
Technically, this means that in order to continue the exchange of information you need to change the tracker address in torrent file from bt.torrents.ru to bt.rutracker.org, (instead of bt can be bt2, bt3 and bt4) or download the torrent files again (they already have a new tracker address).
All the other links on the forum will be changed automatically, but you may need to re-enter login and password when you log on the forum to the browser to remember the new address.
BitTorrent tracker RuTracker.org = http://rutracker.org/forum/index.php
February 18, 2010, 15:20
Уважаемые пользователи!
До конца март нет ограничений по рейтингу.
Сегодня (18 февраля 2010 года) компанией "Ру-Центр" (Москва, Ленинградский проспект, д.74, корп.4, тел +7 (495) 994-46-01 +7 (495) 737-06-01, http://www.nic.ru ) без предупреждения, и какого либо уведомления было приостановлено делегирование домена TORRENTS.RU. По информации из "Ру-Центра" "Делегирование домена TORRENTS.RU приостановлено на основании Постановления следственного отдела по Чертановскому району Прокуратуры г.Москвы от 16.02.2010г"
В "Ру-Центр" направлен соответствующий запрос, однако, весьма вероятно, что выяснение обстоятельств займет некоторое время, в течение которого адрес torrents.ru будет недоступен.
В связи с этим мы вынуждены были в срочном порядке сменить доменное имя на rutracker.org.
Технически, это означает что для продолжения обмена информацией вам необходимо сменить адреса трекеров в уже скачанных торрент-файлах с bt.torrents.ru на bt.rutracker.org, (вместо bt может быть bt2, bt3 и bt4) либо скачать эти торрент файлы заново ( в них уже будет новый адрес трекера).
Все остальные ссылки на форуме будут изменены автоматически, однако возможно вам потребуется заново ввести логин и пароль при входе на форум, чтобы броузер запомнил новый адрес.
18 февраля 2010 года, 15:20
BitTorrent трекер RuTracker.org = http://rutracker.org/forum/index.php
Re: [!]: rename TORRENTS.RU to RuTracker.org
TORRENTS.RU=RuTracker.org Administration reports:
rating is not considered for downloaded files to the end of March
Russian wrote: Итак, первая новость после смены домена.
В связи с необходимостью смены адресов трекеров в заданиях (напоминаю: обновленная инструкция - тут) количество сидеров на раздачах несколько уменьшилось. Чтобы привлечь новых, на трекере объявляется фрилич, пока до конца февраля
Также суточное ограничение на скачивание торрентов для всех на время фрилича повышается до 100.
Качайте, но не забывайте оставаться на раздаче!
Данные о скачивании за текущий день появляются в таблице рейтинга, но не будут суммироваться с общим значением, и не влияют на рейтинг.
Image See how to register
How to download from RapidShare, NAROD, ed2k, Torrents, .... http://plc.net.ru/viewtopic.php?f=2&t=4977
torrent.ru links
Сименовские, Рапидшарные и Народные ссылки http://plc.net.ru/viewtopic.php?f=1&t=2
Simatic EKB Install 2009/08/26
http://plc.net.ru/viewtopic.php?f=1&t=218
http://rutracker.org/forum/viewtopic.php?t=2468134
Siemens SIMATIC Premium Studio 2009 http://rutracker.org/forum/viewtopic.php?t=2060069
SIMATIC Premium Studio 2008 Second Edition http://rutracker.org/forum/viewtopic.php?t=1433383
Siemens Simatic WinAC RTX 2009 v4.5 / WinAC MP 2008 v4.1 /WinAC ODK v4.2 http://rutracker.org/forum/viewtopic.ph ... 5#30443955
PCS7 v7.1 http://rutracker.org/forum/viewtopic.php?t=1881833
PCS7 v7.0 http://rutracker.org/forum/viewtopic.php?t=1393034
SIEMENS SIMATIC STEP 7 Professional Edition v.5.4 SR6 http://rutracker.org/forum/viewtopic.ph ... 7#22605907
Step7 Basic v10.5 для S7-1200 (TIA Portal v10.5) http://rutracker.org/forum/viewtopic.php?t=1946004
SIMATIC NET PC Software, Edition 2008 + SP2 http://rutracker.org/forum/viewtopic.php?t=2514488
SIEMENS SIMATIC WinCC/ODK v7.0 with IndustrialX v7.0 and Prodave MPI IE v6.0 http://rutracker.org/forum/viewtopic.php?t=1981350
Drive ES v5.4 SP4 http://rutracker.org/forum/viewtopic.php?t=2499364
Drive ES v5.4 SP2 http://rutracker.org/forum/viewtopic.php?t=1889069
Drive ES Simatic v5.4 SP1 http://rutracker.org/forum/viewtopic.php?t=1889069
SIMOTION SCOUT V4.1 incl. SP4 http://rutracker.org/forum/viewtopic.php?t=2499364
SIMOTION SCOUT V4.1 incl. SP2 http://rutracker.org/forum/viewtopic.php?t=2356249
PLCSIM v5.4 SP3 + Русский вариант http://rutracker.org/forum/viewtopic.php?t=1909339
SIEMENS SIMATIC PCS 7 V7.0 + SP2 http://rutracker.org/forum/viewtopic.php?t=1393034
Simatic WinCC v7.0 SP1 http://rutracker.org/forum/viewtopic.php?t=2091060
Simatic WinCC v6.2 SP2 Eng http://rutracker.org/forum/viewtopic.php?t=912333
Simatic WinCC v6.0 SP4 http://rutracker.org/forum/viewtopic.php?t=1497565
Simatic WinCC ODK v6.0 [VS2003] http://rutracker.org/forum/viewtopic.php?t=1074740
Siemens Simatic HMI Pro Tool v6.0 SP3 http://rutracker.org/forum/viewtopic.php?t=342953
DVD Русская документация Simatic - 2009 http://rutracker.org/forum/viewtopic.php?t=1329825
SIMATIC S7 Программирование и обслуживание (курс лекций) http://rutracker.org/forum/viewtopic.php?t=740716
SIMATIC S7 Обучение обслуживающего персонала - часть 1 и 2 http://rutracker.org/forum/viewtopic.php?t=741036
Step7/PCS7 by Step training video http://rutracker.org/forum/viewtopic.php?t=2199538
каталог Ca01 Russia 2010 http://www.automation-drives.ru/forum/v ... php?t=5906
pic
Omron CX-One 3.1 http://rutracker.org/forum/viewtopic.ph ... pmode=full
======== Direct links with registred user Simatic_Fan ===============
Simatic_torrent_ru_rutracker.org_links.zip
[dead] :/354136943/S ... _links.zip
or
http://narod.ru/disk/18139079000/Simati ... s.zip.html
CHANt
Post by CHANt »
How correct?
RUS
Последствия чувствуются...У меня раздача Premium Studio 2009 резко снизилась... :(
И ошибка висит какая-то...Кто знает чем лечить?
try over torrent-client
CHANt wrote:Последствия чувствуются...У меня раздача Premium Studio 2009 резко снизилась... :(
Ну во первых весь Китай уже довольно таки давно остался за стенкой.
Во вторых этот трекер недружелюбен к инострацам.
В третьих - за полгода актуальность этой раздачи уже снизилась. Кому было надо - уже скачал. Автоматчиков не так уж и много в мире, тем более сименоводов.
В 4-х - ужем мар, Second Edition то нет !
CHANt wrote:И ошибка висит какая-то...Кто знает чем лечить?
Попробовать другую торрент-программу, хотя при твоем типе связи может просто где-то весенняя вода в кабельных колодцах потекла?
CHANt
Post by CHANt »
over torrent-client with problem too
CoMod wrote:Ну во первых весь Китай уже довольно таки давно остался за стенкой
"А за Великой китайской стеной,
Дяди китайцы храпят...
В речке Янцзы, под янтарной водой,
Лодки подводные спят...
Лодки подводные с красной звездой,
Серп с молотком на боку..у
Завтра, советских подводников строй,
Скажет китайцам - ку-ку..."
:D Чет вспомнилась древняя песенка времен натянутых отношений... :D
Последнее время, в основном ребята из-за океана, потихоньку "тянут"...Пусть весит раздача пока...
CoMod wrote:Попробовать другую торрент-программу, хотя при твоем типе связи может просто где-то весенняя вода в кабельных колодцах потекла?
Не программка не причем. Весной тоже пока не пахнет (по утрам -20) :) , а кабельные колодцы моего провайдера, вдоль дорог на троллейбусных опорах висят... :D Ленивые и жадные, что ЭрТелеком, что УфаНет - подвесными линиями выкручиваются. Скорей всего, опять П2П траффик подрезать начали, осенью шалили в этом направлении. "Еще раз, и (!..) рассержусь, ей богу, рассержусь!" (С) "Жмурки" :)
try change bt -> bt2 or -> bt3
а если переименовать bt в bt2 или в bt3 ?
CHANt
Post by CHANt »
bt3 -> OK
Ага, сработала на bt3...Странно.
Спасибо!
