Dear Experts
I have an old OP5 COROS HMI by Siemens ,
I need to replace a new brand OP5 too so I want to upload the old program from it & download to the new one,but as that an old System
I need to know the type of the software
I should use to do so & the cable pin assignment
Your fast reply is highly appreciated
Many thanks in advance
[?]: Read programm from OP5 COROS and write to new HMI
makas_simatic
Murphy87
Re: [?]: Read programm from OP5 COROS and write to new HMI
If the panel was programmed with Comtext you can upload the program
If the job had been do with Protool you can't upload the program
Eventually if it was a Comtext application there's a Siemens tool to convert to Protool and then you can convert it to WinCC Flexible.
support.automation.siemens 26342385
Murphy
Murphy
