[?]: CP 1613 A2 is not in hardware cataloge
Questions about Siemens & Analog Siemens hardware.
Software & hardware exchanger
hamed14715
Post by hamed14715 »
Hi every body,
I have done HW UPDATE but I can ot find CP 1613 A2(6GK1161-3AA01) in hardware cataloge.
I use CP 1613(6GK1161-3AA00) instead of CP 1613 A2(6GK1161-3AA01)but when I want to download my connection from Netpro I saw a massage for cp 1613 that said my online order number is diffrent offline order number.
Now I dont know how I can find CP 1613 A2 to put in my pc station , My Master bought CP 1613 A2 So I have to use it as my CP. :? :? :cry: :cry:
HWConfig wrote:6GK1 161-3AA00 (=CP 1613 A1 !)
SIMATIC NET CP 1613 Industrial Ethernet, ISO, TCP/IP, S7 connections, H communication, TCP connections, PG functions, PCI bus, routing,
SIMATIC NET CD 2008...
dsekulic
Re: CP 1613 A2 is not in hardware cataloge
Post by dsekulic »
Did You try with IE General (in HW Catalog under SIMATIC PC Station -> CP Industrial Ethernet -> IE General). In explanation said "Substitution for any Ethernet module...". Hope this helps.
or install
STEP 7 Hardware Support Packages (HSPs - Stand: 02/2010)
http://support.automation.siemens.com/W ... e/23183356
regards
hamed14715
I tested IE General & HSPs 12/2009 but my problem dosen't solve.
Image Image
Delivery Release for the SIMATIC NET CP 1613 A2 PC Module (Date:2004-12-10)
http://support.automation.siemens.com/W ... n/20017542
End of Production for SIMATIC NET CP 1613 A1 PC Module (Date:2009-06-23)
http://support.automation.siemens.com/W ... n/36843707
dsekulic
Post by dsekulic »
What about content of installation CD delivered with CP1613 A2.
There should be HSP with CP1613 A2.
SIMATIC NET 2008 SP2 http://plc.net.ru/viewtopic.php?t=8339
regards
hamed14715
Hi
SIMATIC NET 2008 SP2 had been installed On pc and CP is known by pc.
Best regards
Umencho
Post by Umencho »
Did you tried with clean, delete everything restart of PC and build from the beginning. Basically dseculic is right. If you put there IE general this should be recognize later like CP1613...
Best regards,
Umencho
hamed14715
Dear Umencho
I know you and I'm thankful for your helps .
I will try to start from begin and configure it again.
Best regards
