[LINK]: WinBass II (Baumüller)
Прочие PLC и HMI на русском
Grey
Post by Grey »
Други, срочно нужна прога WinBass II для конфигурирования драйверов Baumüller.
Поставщик прислал по гарантии уже 3-й драйвер BM3xxx с неверной прошивкой, а оборудование стоит.
http://www.baumueller.de/e_servo_contro ... nbass2.htm
aborigen
Re: Request: WinBass II (Baumüller)
Post by aborigen »
[dead] letitbit net Baumuller.rar
Don't worry, be happy. :wink:
almanzo
Re: [LINK]: WinBass II (Baumüller)
Post by almanzo »
I can not download this web we need RS Thanks
vlad2006gr
Post by vlad2006gr »
Rapidshare link. [dead] Baumuller.002 Baumuller.001
Combine Total Commander.
Good luck!
vlad2006gr
Narod mirror. [dead]
narod ru disk Baumuller.001 Baumuller.002
Good luck!
jkovacs
Post by jkovacs »
Hello guys
The file Baumuller.001 is corrupt. Could it reload the good version someone, please?
Thanks and best regards
vlad2006gr
Link : [dead]
narod ru disk Baumuller.001 .002
It's working! Check!
jkovacs
Post by jkovacs »
Thanks for your prompt reply.
The packed files are available, but some of them damaged on the server.
The packed files are downloadable - but unfortunately, some files are damaged. Just check separately the "Setup.W31" file on server. It is doesn't downloadable.
This file is surely missing from downloaded archive "Baumuller.001" and the unpack process gives fault message --> CRC Error in Setup.W31.
Also the other file "Setup_Update_V1_109bd44.zip" is damaged. Error message during unpacking --> Error: End-of-central-directory signature not found.
Can you check your ones, those are unpackable as well, please? Maybe it needs simply an upload again onto the server?
Many thanks and best regards
vlad2006gr
Ok. New link Setup_V1.09bd43
[dead] yadi.sk
or
[dead] rapidshare com
Update:
http://www.baumuller.ch/DownloadInterne ... 09bd44.zip
http://www.baumuller.ch/DownloadInternet/update_winbass/Setup_Update_V1_109bd44.zip
Good luck!
jkovacs
Post by jkovacs »
Many thanks, it works as well. :-)
Best regards
hmohamed
Post by hmohamed »
Links are Dead can you reupload
vlad2006gr
Relink [dead] yadisk
Good luck!
craul3
Post by craul3 »
Hello
Can you , please reupload WInbass 2? Thank you
craul3
Post by craul3 »
Hello
can you reLink Winbass2 , please ?
Thank you
Best regards
vlad2006gr
after 11 May will try to help. whilst on holiday.
craul3
Post by craul3 »
OK Thank you .
vlad2006gr
craul3
Post by craul3 »
Thank you very much .
Best regards from me to you .
Thank you again .
elhazard
Post by elhazard »
anyone can share a working link to w1nbass 1
ppp
Post by ppp »
elhazard
Post by elhazard »
thx!
jimmy146
Post by jimmy146 »
Hi, can anybody reupload WINBASS II ?
Updates are avalible from baumuller site without problems, but first install is hard to find - all links are dead now.
Thanky you!
(fback)
alexpin
Post by alexpin »
Срочно понадобилась WinBass II могли бы Вы обновить ссылки
ppp
Post by ppp »
pbfilho
Post by pbfilho »
Hi, i`ll appreciate very much if somebody can upload fresh links for WINBASS II.
I have a urgent demmand with parametrization of a BUS621 drive.
Thank you in advance.
mindegy
Post by mindegy »
All links are dead now.
Thanky you!
(oo)
arslan
Post by arslan »
Hello Everone,
We have Baumuller BUM61-40/60 servo drive, originally it was commissioned in speed control mode but now we want to
change it to position control mode. if some one has manual that how can we change it position control mode and control the direction of motor by means of digital inputs, please share with me the manual.
Win are using WINBASS I software.
Arslan
Skippy
Post by Skippy »
Hello!
Can somebody can reupload Winbass II ? Thx very much :)
KamelHDMI
Post by KamelHDMI »
Please dear can you re-upload the Winbass II with a working version.?!
Please support me.
Здравствуйте,
Мне нужна рабочая версия WinBASS II.
Я установил одну из версий, но во время установки возникает ошибка, связанная с I/O (ввод/вывод).
Пожалуйста, окажите поддержку и помогите решить эту проблему.
Спасибо.
