[?+]: convert old project wincc flexible 2005 to 2008
aguere
Post by aguere »
Hello, I can´t convert project wincc flexible 2005 sp1hf7 to wincc flexible 2008.
Someone know why not?
Thank you very much
Re: Help old project wiflx2005
open project with Flex 2008,
convert start automaticaly
If you open an old WinCC flexible project with a more recent version of WinCC flexible, you first get a message indicating that the current configuration has been created with an older version of WinCC flexible.
After acknowledging this message, the project is converted automatically to the latest version. A backup is also made of the "old version".
You can then edit the configuration and save it via the menu item "Project > Save as version". More information is available in Entry ID: 33934262 .
