[?]: cable for slc 500 plc?
zaji
Post by zaji »
Dear Every body
i want cable for communication for slc 500 plc of allen bradley?
can any body help it?
dehell
Re: [?]: cable for slc 500 plc?
Post by dehell »
For connecting SLC5/03, SLC5/04, SLC5/05 you can use serial cable (RS 232)
Follow the link for schematic.
Best regards.
[dead] :/344461295/1 ... t.pdf.html
or
http://narod.ru/disk/17492819000/1747-C ... t.pdf.html
zaji
Post by zaji »
thank u for kind reply,,but in plc there is a RJ45 connector then how can i use serial cable RS232? as i needed RJ45 connectivity.
zaji
Post by zaji »
the link below given by you is supported by adobe photo reader,kindly revise it if you could help
thanks
dehell
Post by dehell »
For SLC5/05 ->RJ45 connector is an Ethernet port: you need a cross wired ethernet cable for connection.
For SLC5/01 or 02 or 03, you need a converter RS232->DH485 or USB->DH485
http://literature.rockwellautomation.co ... _-en-p.pdf
You can buy a chinese made remplacement product (it's cost only 23$)
http://www.fractioni.com/inc/sdetail/275
For reading pdf files, you can download "Foxit Reader" (free software). Use Google to find it.
Best regards
SLon
Post by SLon »
... you can to use for connection to SLC5/01 or 02 or 03 (with DH485), any converter RS232->RS485 (not only from AB)...
(as example ADAM-4520)
